Lift pump
Old Apr 9, 2014 | 09:44 PM
slowboogy's Avatar
Default Lift pump
I was wondering what everyone's take is on direct replacement lift pumps.. I am thinking about getting a 100gph or 150gph and I was just wondering is it better to relocate the lift pump or about the same to just replace the stock one in its regular spot with a upgraded one. Thanks in advance
99 3/4 ton 5 speed 5 inch turbo back to 12 inch tip
Old Apr 9, 2014 | 10:12 PM
lukesdiesel's Avatar
I would look at a Fass Titanium 150.
DieselDawg
Old Apr 11, 2014 | 06:54 PM
GHOST806's Avatar
i went with a raptor 150 and have had 0 issues with it.
Old Apr 11, 2014 | 11:08 PM
lilmike1540's Avatar
I also have a raptor 150 and if you go with a raptor the only issue i have with it is that somtimes it can be tricky to prime and make sure you get the frame mounted unit
Old Apr 13, 2014 | 09:27 PM
slowboogy's Avatar
So not the frrp raptor 150? Is there any difference
Old Apr 14, 2014 | 04:06 PM
Yes the frrp is mounted in the stock location and is rattled to death and the frame mount unit is only 375$ at bluechipdiesel comes with 1/2 line from tank to filter houseing then you just get some 1/2 fuel line from the filter to the vp with the right fittings or the vulcan big line kit .
HeavyChevy95
Dec 21, 2016 10:36 PM
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
