What tuner should I get?
Old Apr 8, 2014 | 11:07 AM
Ethancs1990's Avatar
Default What tuner should I get?
Hey guys I'm looking to start upgrading the performance of my 98.5 cummins. I think I'm going to start with a tuner and 4" exhaust. I was looking at the edge EVO. What are everyone's thoughts about it?
Old Apr 8, 2014 | 12:24 PM
lukesdiesel's Avatar
Edge Comp is best choice or Edge Juice with CS/CTS
Luke@DieselDawgs.com
Old Apr 8, 2014 | 01:22 PM
Pclem's Avatar
I'm either going with the comp box or the chip I found on http://www.dieseltunesperformancechips.com/1998-2000-59l-dodge-cummins-diesel-chip
Both are good options. I like the diesel tunesnkne because it doesn't muck with fueling. Its all timing based.
Old Apr 9, 2014 | 01:26 AM
lilmike1540's Avatar
Edge comp will be the very best if you buy a tunner and it doesnt require you to tap the pump then your only going to get a tunner capible of 60 hp over stock
Old Apr 10, 2014 | 02:46 PM
cerickson's Avatar
Edge comp get's my vote. Works well on my truck.
Old Apr 18, 2014 | 04:42 PM
jigabop's Avatar
make sure you upgrade your lift pump and get gauges before you run any performance boxes...
Old Apr 21, 2014 | 04:28 PM
vcustoms86's Avatar
X2. Also, if you tap the pump use a BD stealth pump cover. Makes tapping the pump alot easier. I run Edge Juice. Messing with fuel isnt bad aslong as you make the correct modifications first.
Macster86
Ford Powerstroke 08-10 6.4L
Jul 21, 2015 09:23 AM
Whizbang
Jun 24, 2015 02:12 PM
tenwheeljoe
May 27, 2015 04:00 PM
slowstroke
For Sale
Apr 1, 2015 11:35 AM
leaderbeanjr
For Sale
Jan 20, 2015 01:22 PM
