smarty good for stock 48 re tranny?
Old Apr 5, 2014 | 04:45 PM
Zak27's Avatar
Default smarty good for stock 48 re tranny?
im looking into the smary pod s-06 programmer and i was woundering if it would be safe for the stock 48 re tranny for my cummins? what level would be safe? sw3,4,5,6?
Old Apr 5, 2014 | 08:00 PM
madhat's Avatar
The smarty paperwork says SW 3 is the highest you should go with a stock auto. I'd keep the torque management low as well. The harder you beat on it, the shorter it will live.
Old Apr 5, 2014 | 08:06 PM
cerberus60's Avatar
Consider this; you can kill a stock transmission on stock power, or, run Smarty on SW9 and not kill the trans. Short answer is a lot depends on your right foot and all the other settings on Smarty.
Basically, you could probably run SW2 and use it all without hurting things. If you try to run SW3 or higher and reduce the TQ management to where the truck responds so much better to throttle it is only a matter of time until it torches the direct clutch pack and likely ruins the input shaft.
If you want to make use of the power and the settings to optimize the driving experience you NEED to upgrade the trans to a degree. A shift kit, billet band strut and anchor, front servo cover will allow you to get pretty aggresive up to SW6 or until the TC gives up, that will be the weak point after the other smaller upgrades.
Old Apr 6, 2014 | 01:19 AM
crf450x's Avatar
Like said, it all depends on how you drive. And a huge part of it also is luck. I have a buddy with efi live and a 64 running a stock trans with 200k on it and it's still kickin. So you may get lucky....don't count on it though.
Old Apr 6, 2014 | 05:54 PM
mykaos's Avatar
Additionally to what's already been said, remove the TC Anti-drain back valve, turn up the line pressure a tad. Mine survived over 30,000 mi w/ Crazy Larry and another 4,000 mi with compounds...
Old Apr 18, 2014 | 11:09 PM
Zak27's Avatar
It's a new 48re tranny or stock tranny but thank you for the advice and let me know more please
Old Apr 19, 2014 | 05:11 AM
lukesdiesel's Avatar
Install a good aftermarket valve body and torque converter
Sent from my DROID RAZR using Tapatalk
Old Apr 19, 2014 | 03:52 PM
Zak27's Avatar
What about input and out put shaft with the valve body and tc
Old Apr 19, 2014 | 08:25 PM
Bigg Redd's Avatar
An inline auxillary trans cooler cant hurt.........to help keep trans temps in check.
Old Apr 20, 2014 | 10:05 AM
Zak27's Avatar
how well does a smarty jr work for the stock tranny? on sw3 says its 100 hp any different then the pod?
