4WD ing a 2WD Dodge Cummins?
Old Apr 4, 2014 | 11:08 PM
Joerg's Avatar
Default 4WD ing a 2WD Dodge Cummins?
Dear Dodge Cummins Community,
is it a lot of work to convert a 2wd Cummins into a 4 WD?
I have a 1993 2 WD auto - can I use the tranny and just add a transfer case?
What else do I have to do?
Which components would I need?
Thanks.
Jörg
Old Apr 15, 2014 | 12:39 AM
Fluffy nuts's Avatar
Yes it is hard or time consuming or both. No you cannot use the current transmission its a two wheel drive transmission period um gonna need a new 4wd front axle geared the same as your rear gonna have to acquire a front driveline probably shorten your rear driveline probably a different crossmember I don't know ive never been under a 2wd before cut a hole in the floor board for the t-case shifter im sure theres more but theres just a start for ya
Old Apr 19, 2014 | 09:39 AM
mknittle's Avatar
It's a pretty common swap. I am about to do one. It is a lot of work but not that hard to do compared to other makes. The best way to do it It is to find a donor truck.
Old Apr 19, 2014 | 10:36 PM
burnhedge's Avatar
Cheaper to trade up to a 4x4 unless you have a 4x4 parts truck to steal from. The price of a good Dana 60 front will blow your mind. Not to mention all the other expenses.
Old Apr 21, 2014 | 08:09 AM
mknittle's Avatar
Funny thing is you can often find a body damaged truck or rollover cheaper than a Dana 60 front.
The only problem is finding a decent 4X4 first gen at a decent price.
Old Apr 22, 2014 | 08:35 AM
ZAAR's Avatar
most people with experience will tell you its cheaper to find a truck already configured to a 4wd platform from factory if your feeling crafty go for it, but be prepared to spend way more money for the parts to convert than It is to find a full truck.
granted it is hard to find a solid 1st gen 4wd that has not been neglected or molested.
know that the transfercase the trans and your driveshaft needs to be changed.
front diff steering components and im not sure what trans you have in there cross member has to be re positioned and would be easier to find another one and measure it out properly. lotsa work buddy and if you take it on good luck.
Old Apr 22, 2014 | 09:20 AM
mknittle's Avatar
Hell I have been building cars and trucks for 40 years 20 of which I was a machinist. this is a Pretty simple swap for me. the hardest part is getting started
PS have all the parts and have made some that I didn't like or have. Plus I have become attached to the truck that I have had for 18 years. Thanks for the warning though
I have a build thread going here.
1990 D250 to W250 - Dodge Diesel - Diesel Truck Resource Forums
Old Apr 22, 2014 | 10:36 AM
91 7three's Avatar
I was thinking you could use the same transmission but use an output shaft from a 4x4 trans.
Old Apr 22, 2014 | 10:54 AM
mknittle's Avatar
Yeah if you have the adapter and a transfer case that has the correct spline count. from what I read there are two different spline counts for the NP 205 Dodge used. manual and auto. I got almost all my parts from the same truck. so I haven't looked into mixing and matching much.
I know this type of project isn't for everybody. To me it is fun. My wife says it beats dragging me out of bars.
Old Apr 22, 2014 | 11:04 AM
91 7three's Avatar
It doesnt seem like it'd be too difficult of a conversion but definitely time consuming. Front end would probably be the hardest part of it because i think you would have to drill the frame for the shackles and what not.
