Do 24v 5.9's need to warm up?
For about ten minutes after I start up, here in balmy SoCal, there does not seem to be much power/throttle response. After about ten minutes it is fine. Is that normal? If it is, what is it that causes it to do that? Thanks
Thats normal. Any engine runs better once warmed up. Most diesel programmers will not add power until atleast 140-150 degrees. Some you are able to turn it off. Its safer to get heat in the motor before beating on it.
Bigredpowerstroke
Aug 14, 2015 10:31 AM
