1986 6.9 problems
Old Mar 31, 2014 | 11:12 PM
Olddiesel's Avatar
Default 1986 6.9 problems
86 f250 6.9. Not sure how many miles are on it but I've had it for about a year. Ive been having a rough idle. Sometimes it would die on me at stop signs but as long as i was over 1000rpms it ran fine even more power than usual. I have replace all the return lines and o rings and also i don't use my rear tank and ran new lines to bypass that switch on the frame and the old water separator. After i ran the new fuel lines it ran like a top intel the idle problems started. I have new injectors on the way. Any suggestions would be appreciated
Old Apr 1, 2014 | 05:03 PM
4x4manonbroke's Avatar
Probably need to bump your idle up to 800-850 ... Run about 2 quarts of dextron ATF and run in down good long stretch of highway .... Should help a bit ... If not ... Proceed in replacing injectors ...
Old Apr 1, 2014 | 07:37 PM
Olddiesel's Avatar
Thanks for the advice. Now i took it to work this morning it ran pretty good but on the way home i could barley make it up a hill. I was only going about 20mph floored no power it was just bogging out. Injection Pump?
How do i turn my idle up???
Dbleo351
Nov 20, 2016 09:34 AM
tom88k5
Jun 16, 2015 12:57 PM
Blanton
Apr 15, 2015 06:29 PM
tumble72
Nov 10, 2014 08:41 PM
murderedf250
Oct 15, 2014 04:26 PM
