1999 Cummins, Drag comp box info needed
Old Mar 28, 2014 | 06:42 PM
MOPARTIM's Avatar
Default 1999 Cummins, Drag comp box info needed
Hey friends... I just purchased a edge COMP BOX + hot unlock. Going to instal next week. Questions are will I be ok with egt's? Will stock vp44 that's Fed by fass150gph be ok? I have stock turbo and injectors. I plan to use the box daily for fuel mileage savings and briefly and occasionally on level 5 for light to light fun. I have only a boost gauge and low fuel pressure warning light. I am I headed for disaster? Or years of safe fun?
Old Mar 29, 2014 | 10:24 PM
lilmike1540's Avatar
Tranny tranny tranny ...!!! no more then 100 hp over stock should be fed to your tranny giving that you have the shitmattic vp should be fine with lift pump stated turbo dont go over 30-35 and injectors will top out befor you turbo a set of 125# will do wonders for a stocker ...
Old Mar 29, 2014 | 11:52 PM
MOPARTIM's Avatar
Hey man, thanks for taking the time to answer!! Just to clarify...30-35(you mean boost psi right)? And 125# (you mean 125#horsepower injectors)? If so..... I hear 75horse power injectors maximum with stock turbo...?!?!
Btw... Forgot to mention earlier... She is a manual...6speed!! With a Sweet *** Hurst Pistol Grip Shifter!
Old Mar 30, 2014 | 10:33 AM
Oh ok well level. 5 is able to handle just no clutch dumps unless you have a upgraded clutch and with injectors you ALWAYS want to go bigger then reqired that way you arent maxing out the injector and you can use your comp box to do as it needs to with out maxing the injectors out not only that but if you want more power you have it ready to go and 35 psi of boost is the most you want to put through your hx35 if its the stock turbo..it takes less stress on your system if your capaple of 700 hp but only useing 500hp hope this makes sence
Old Mar 30, 2014 | 03:05 PM
MOPARTIM's Avatar
Thanks again bro.....
scottxmorris
Jan 11, 2025 11:24 PM
RexShoppe
Price Quote - Request A Price
Nov 23, 2015 02:38 PM
DirtyDiesel58
18
Sep 27, 2015 07:07 AM
Rusted Dragon
Feb 27, 2015 09:46 PM
mcclusk
Feb 21, 2015 09:50 PM
