No Start: High Pressure Oil Pump & Fitting Removal
Old Mar 23, 2014 | 06:29 PM
makuloco2000's Avatar
Default No Start: High Pressure Oil Pump & Fitting Removal
Ok so this is a real common issue and the latest design high pressure fitting is a permanent fix from Ford. This issue of blown apart STC fittings started with the redesign in 2004.25. I really thought all of them were replaced by now with one of the two redesigns Ford came up with, I was wrong! Here we have a 2005 F250 no start due to this fitting coming apart so bad it cracked the rear cover. I know if I owned a 6.0L this would be on the top of my to do list for sure BEFORE it fails so I don't get stranded. What is worse is a cracked rear cover is $400 alone not to mention labor. Call this preventative maintenance and here is how to do it in your driveway!
BKID
Jul 25, 2015 07:59 PM
ramrunner01
9
Jun 4, 2015 03:34 AM
Gm3500
May 7, 2015 11:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
