truck has miss need some help
Old Mar 23, 2014 | 11:18 AM
strokedout07's Avatar
Default truck has miss need some help
Buddy of mine has a 04 6.0 truck has a miss and hooked up computer said injectors 1,5,&7 were spratically firing replaced them and the same problem persists any insight and help from u guys would be helpful
Old Mar 23, 2014 | 05:23 PM
Adrenaline junkie's Avatar
Did you check the wiring harness to the injectors? I would go over harness very carefully. I would also look at the ficm.
Old Mar 24, 2014 | 08:40 AM
Looked ok and computer didn't show any interrupted power or short to grounds
Old Mar 24, 2014 | 12:10 PM
bobfbigman's Avatar
A weak FICM will often throw codes for one bank of injectors, if suddenly you have multiple injectors on the same bank not firing properly then the most likely cause is the FICM, test the FICM as described in the "Sticky" section at top of the 6.0 page., they can be repaired for a lot less then new and they will even be a lot more reliable in the future compared to new.
doublehbar
13
Aug 9, 2015 12:35 AM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Dec 3, 2014 09:40 AM
Oct 14, 2014 08:40 AM
