03 6.0 do or don't?
Old Mar 22, 2014 | 11:25 AM
Dieselinmyveins's Avatar
Default 03 6.0 do or don't?
I'm looking for my first diesel and I found this 03 6.0 4x4 2003 Ford F-350 Pickup Truck | cars & trucks | Winnipeg | Kijiji it has 231,000km (143,000 miles). I know 6.0's have a bad reputation but this is a good deal so I thought i'd ask about it. it looks in good shape, is there anything I should ask him or look for on a 6.0l? I don't plan on doing a lot of towing and I'd probably just do exhaust, intake and a chip. what would I need head studs and everything to make this truck at all reliable?
Old Mar 22, 2014 | 11:58 AM
Adrenaline junkie's Avatar
See what mods were done and when. See how truck performs now, and drive it. If you can get to mechanic look for stored codes with diag tool. I love mine for what it's worth!
Old Mar 22, 2014 | 01:44 PM
does the truck in the link I posted look like it has anything done to the engine like an egr delete or anything?
the owner said in 2012 he put new injectors in and a new FICM as well
the truck is stock no deletes or studs
Last edited by Dieselinmyveins; Mar 22, 2014 at 01:44 PM. Reason: Automerged Doublepost
Old Mar 22, 2014 | 07:34 PM
Egr is under intake on passenger side. You can plug ends go egr but most just eliminate it if they are that far in.
Looks like nice stock truck for the money!
Last edited by Adrenaline junkie; Mar 22, 2014 at 07:34 PM. Reason: Automerged Doublepost
Old Mar 22, 2014 | 11:22 PM
do stock 6.0's stretch the headbolts and blow headgaskets? do they always need head studs?
Old Mar 23, 2014 | 11:24 AM
Asheville Engine's Avatar
Three major things that I would check? 1) is there any evidence that the degas bottle has been puking? 2) is there any diesel fuel/smell in the degas bottle. 3) is there any crankcase pressure? take the oil fill cap off and put your hand over it.
Any of these could lead to major engine work or replacement.
Old Mar 23, 2014 | 11:35 AM
should there be some blowby coming from the oil fill cap? I heard the best way to check it is to set the cap on it and if it falls off it has excessive blow by, is this a good method?
Old Mar 23, 2014 | 05:31 PM
If you mod them they have more of a tendency to stretch bolts and blow gaskets.
Old Mar 23, 2014 | 11:16 PM
with just a chip, is there a high risk of that happening? would you be a lot better off to bulletproof it before a chip?
Old Mar 24, 2014 | 05:39 AM
You can get a ficm tune from different vendors that adds 40, 80, or 100 hp. I have a 40 since I tow heavy sometimes and it really wakes it up! I didn't do studs yet but I'm doing gauges and supporting mods,( see sig) so I'm ready. Truck runs pretty good as is so tuning isn't high on list right now! I depend on mine for daily driver,would recommend backup transportation if you want to tune jic.
