1989 w250 wrist pin failure
Old Mar 20, 2014 | 11:27 AM
wvwelder89's Avatar
Default 1989 w250 wrist pin failure
I have a 1989 w250 and the number 6 cylinder wrist pin is shot what all do u normally half to replace when this happens ?
Old Mar 20, 2014 | 06:49 PM
novapat's Avatar
if it has not completely let loose and killed the cyl. you will be doing a piston that comes with the pin. rings and of coure head gasket and pan gasket.. norm. the bushing in the rod is okay but I would check it..
Old Mar 21, 2014 | 11:12 AM
wvwelder89's Avatar
I don't think it has let loose but I've only looked at it from the bottom up can't really tell a whole lot but you can tell that the piston has gotten pretty hot
Old Mar 22, 2014 | 12:53 AM
novapat's Avatar
might want to check the piston cooling nosile.
Tucker126
Jan 2, 2015 08:09 AM
