Oil color differences
Old Mar 19, 2014 | 09:16 PM
DrivenMad's Avatar
Default Oil color differences
Hello everyone Thank you for the Amazing help and support in the past!!
I have a 2004 f250 with a 6.0 powerstroke manufacture date 5/19/04
I have been hunting down low end oil pressure problem. I have done hpop, seals , dummy plugs, etc. on the high pressure side. I was still getting no hpop pressure with scangauge 2.
I hooked up a low oil press. gauge at the sensor behind the oil filter housing and still got no readings even after long cranks.
My question is, I notice a different in oil color between the filter housing ( super black) and the oil at the low press. oil pump gears behind the harmonic balancer (new oil color light tan/clear).
Should the colors be like that?? I know the oil comes from the pump to the oil cooler res. then to the filter housing, then to the engine. Any ideas? Its almost like the oil is not circulating.
Thanks a bunch!!
DM
Old Mar 19, 2014 | 09:53 PM
Canadian country boy's Avatar
Your high pressure oil could be a bad ICP sensor that would give you low reading .
Also if you have been into the oil system and didn't make every thing was really clean you possibly could of got some junk in that little screen on the IPR . There also is screen in the bottom of the oil cooler reservoir.
Also you could switch out your LPOP just thought.
Old Mar 19, 2014 | 09:57 PM
DrivenMad's Avatar
Thanks I will pull the Ipr and check the screen. I just put a new one in it I was thinking of just doing a oil cooler kit and doing that screen to
THanks
DM
Old Mar 19, 2014 | 10:08 PM
What about your LPOP.
Old Mar 20, 2014 | 01:26 AM
DrivenMad's Avatar
yes, getting the gears tommorrow
Old Mar 21, 2014 | 09:45 PM
How did you make out with your oil problem.
Old Mar 24, 2014 | 06:05 PM
tiremann9669's Avatar
What oil filter you have on there ?
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
jhprice
Mar 29, 2015 09:36 PM
coors_man_2005
Dec 15, 2014 10:23 AM
