Dana 60 Front Axle ?
Old Apr 23, 2008 | 10:49 PM
00' Quad Cab's Avatar
Default Dana 60 Front Axle ?
Anyone done the Dana 60 axle seals themselves? How much work? what kind of special tools?
I have a left side seal leaking. Looking to do both seals and axle u-joints for sure.
Anything else I should be looking at?
Old Apr 23, 2008 | 11:02 PM
94cummins12v's Avatar
pain in the *** let me tell ya
pull the wheel get a hub puller, lossen 4 hub bolts and pull the hub. except on mine it split the bearing si i had to heat the spindle to get the bearing carrier off on mine but after that was out smoth sailing from there dont know about the seals though i have to do mine soon
Old Apr 24, 2008 | 03:55 PM
prromine's Avatar
The repair manual says roughly 8 hours. You have to almost strip the axle.
remove: Wheel covers?, tires , calipers, rotors, hub bearings, axle shafts, vacuum shift, other half of pass. side axle, diff. cover, ring and carrier. It helps to take one end of the tierod off the spindle. Sometimes the carrier will come out easy. Other times you have to spread the diff. housing a little, or pry easy. Make sure you put the pieces that hold the carrier in the way they came out. (same side and face the same way)
To install the seals you can buy the tools or find the driver that fits the seal and make your own tool to put the seals in. They call them drivers but you actually pull them in place.
oh , and get an extra set of seals just in case.
Hope this helps, it was a pain when I done mine. Thankfully my Dad had the hoist.
Good Luck!
carid
Diesel Bombers Sponsors
Aug 11, 2015 06:24 AM
Natenelson1
Jan 19, 2015 07:23 PM
KYLEBOY
Jan 18, 2015 06:36 PM
natenel1
Oct 26, 2014 03:09 AM
