Help!!!
Old Mar 17, 2014 | 06:45 AM
24vgirl88's Avatar
Default Help!!!
Help! I'm getting two trouble codes...
P0216 and P1693 .... All I'm reading online is that these could be vp44 death codes.. Is this true?? Anyone have any idea what they really mean??..
Old Mar 17, 2014 | 10:59 AM
lukesdiesel's Avatar
P0216 DTC - Injection Timing Control Circuit Malfunction
P1693 just means you have a code
Luke
Old Mar 17, 2014 | 01:59 PM
24vgirl88's Avatar
Is it in definately mean it's my lift pump ?
Old Mar 17, 2014 | 03:25 PM
Bigg Redd's Avatar
Before you start throwing money at it, check and clean your battery terminals, as well as all of the ground connections in the engine bay. There are several. A bad ground will cause havoc with codes. Also make sure all plug-in connections are tight. I had the same issue a couple of years ago. I was sweat'n bullets. Turned out to be a bad ground to the ecm. I now make a point to clean all ground connections yearly. That tidbit of information was found in this forum. Best of all, it didnt cost me any money, just a little bit of time.
However, if it turns out to be your lift pump, address that immediately, before you burn out your injector pump.
