Please help stuck on the side of road w/ babies in vehicle
Old Mar 16, 2014 | 09:07 PM
Hounddog55's Avatar
Default Please help stuck on the side of road w/ babies in vehicle
2003 Ford excursion 6.0l
accelerated away from stop light truck began to shake battery light came on then check gages light lost all power will crank no start. This is my first Ford so i know nothing about them. Please help
Old Mar 16, 2014 | 09:50 PM
Adrenaline junkie's Avatar
I'm guessing oil pressure problem or ficm. . .either one you prolly need ride home. You can test ficm and see if u have 48 volts.
Old Mar 17, 2014 | 04:11 PM
Hounddog55's Avatar
Thanks for the reply tow truck came and towed me home after dropping it off she fired right up. Could this be a fuel filter problem? I have only had the truck a week now so I'm a Lil clueless. I know nothing about these power strokes as I was a Cummins one before. All jokes aside I do appreciate the help.
Well that didn't work went out this morning to start her up and the same result as last night. All crank no start. had a buddy tell me to replace the camshaft sensor. any thoughts? is this something I can do or? pulled the fuel filter and it looks clean but the cap was so tight it busted while trying to get it off.
Last edited by Hounddog55; Mar 17, 2014 at 04:11 PM. Reason: Automerged Doublepost
Old Mar 17, 2014 | 04:29 PM
mysterync's Avatar
I wouldn't recommend just putting a sensor in it. I'd find a qualified shop and have the truck diagnosed! These trucks have hundreds of different scenarios that will cause a hard start. Some of them with a basic scan tool we can help you diagnose at home, some you'd likely need to find a good shop. Long story short, if you need it back quickly and can't afford to replace a ton of parts with the parts cannon you need to tow it to the shop!
Sent from my SCH-I605 using Tapatalk 2
Old Mar 17, 2014 | 04:58 PM
Tweaker727's Avatar
First things first!
Ditch the "Edge Juice w/ Attitude" You have listed in your Signature!
I've known SEVERAL people on the forms that had erratic issues with these (or tuners in general)
Second, Do you have access to a code reader or a chance to buy a scangauge 2?
You can do a bit of diag work yourself with a scangauge. Check these out
There aren't really a TON of reasons that the truck would die and re-start again later
Old Mar 17, 2014 | 05:25 PM
mysterync's Avatar
Originally Posted by Tweaker727
First things first!
I can count at least 100 I've experienced in the last 6 months alone...
Old Mar 17, 2014 | 10:12 PM
Bulletproof diesel is advertising a cool gauge for about $170 that plugs into obd 2 port and can give you quite a bit of valuable info. I would definitely check ficm volts when cranking since it's easy and free. Doesn't hurt to eliminate that possibility.
Old Mar 17, 2014 | 11:30 PM
Canadian country boy's Avatar
Like the guys above said a good place to start will sudden troubles is the Ficm. A few tips for a new 6.0L owner. Don't just read these posts and put parts on and hope for for the best . Find a really good shop or get a proper scan tool and do some research and fix it your self. Just putting parts on 6.0L will get you no were you have to find the real problem to fix it.
Old Mar 22, 2014 | 03:18 PM
Hounddog55's Avatar
so here is an update i got from the shop on Friday it seems that the problems I'm having are being caused by the Edge juice with attitude. they are going to run another diagnosis on Monday after the chip is out and see if there is anything else that might be there. has anyone ever heard of this?
Old Mar 22, 2014 | 07:30 PM
I have heard of multiple programming issues with the edge. And other problems too. If you want tuner for 6.0 get sct with custom tunes for your truck.
