Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
05 durmaxsta
Old Mar 16, 2014 | 06:40 PM
FishHook2014's Avatar
Default 05 durmaxsta
need help new to site truck shut down at idle no start back and wont crank battery good &starter can short out &turn truck over
Old Mar 16, 2014 | 09:32 PM
2004LB7's Avatar
cant say why it happened but check the mega fuse
Old Mar 17, 2014 | 05:29 PM
ck all fuses they are good
Old Mar 17, 2014 | 09:51 PM
2004LB7's Avatar
if you jump the starter relay in the fuse box does it turn over?
what about the NSBU switch? try cranking in neutral.
did you check the 175 amp fuse under the fuse box hood?
