Does This Look Bent To You?
Old Apr 23, 2008 | 04:55 PM
nooblet's Avatar
Default Does This Look Bent To You?
Does this look right to you guys? My steering is off and I can't figure out why. I think the draglink might be bent, but I can't tell without another one right next to it.
Post up a picture of yours, or just look at yours and tell me if mine looks different.
Chris
Old Apr 23, 2008 | 05:24 PM
RSWORDS's Avatar
Looks just like mine!
Old Apr 23, 2008 | 06:35 PM
Whit's Avatar
Site Mascot
looks OK to me.......tell us whats off with yer steering??
what ya meanin Willis?
Old Apr 23, 2008 | 06:38 PM
nooblet's Avatar
it pulls to the passenger side, and the steering is offcenter. Half a turn of the steering wheel to the drivers side makes my truck go straight. I can't figure out whats wrong.
Chris
Old Apr 23, 2008 | 06:55 PM
Whit's Avatar
Site Mascot
jack the front end off the ground and put 2 jack stands under the frame allowing the whole front suspension to dangle
get under there and check everything .......look for loose parts on the track bar, steering arms, pitman arm, steering box and anything else that moves.....check yer ball joints too
Old Apr 23, 2008 | 07:25 PM
nooblet's Avatar
The truck is jacked up and being supported by the jackstands you can see in the background of the pictures under the frame. These trucks don't have ball joints...
Chris
Old Apr 23, 2008 | 10:12 PM
GO OVRIT's Avatar
Or track bars Are you sure its not in the gear box? I see the pins didn't get sheered.
Old Apr 23, 2008 | 10:16 PM
Diesel-N-Dust's Avatar
Tires, Rotate them around and see how it drives then.
The secret for a big truck on Big tires to drive straight is : Rotate, Rotate, Rotate.
Old Apr 24, 2008 | 08:16 AM
MotorOilMcCall's Avatar
Could be your whole axle is misaligned, or your tie rod isn't setup right, meaning you have too much toe in or out. And your right, they don't have balljoints, but kingpins can still wear out, especially if they are way overtaxed, ie. big tires. Check them to see if they are loose at all.
I would take some measurements and find out if your springs are truly parallel, it may be a long shot, but it happens.
Other than that, take it to an alignment shop and let them try to figure it out.
Old Apr 24, 2008 | 08:28 AM
Johnny Cetane's Avatar
If your truck pulls fairly hard in the same direction as the wheel is off then I'd bet on tires.
Another possibility is a dragging brake caliper. I've had one bad enough to turn the wheel. If you step on the brakes fairly hard does the truck do straight?
