Code Won't Go Away
Old Apr 23, 2008 | 04:18 PM
solostyle's Avatar
Default Code Won't Go Away
P0299 Turbo/Supercharger Under Boost
it keeps showing up and now i cant just erase it with the BD. it says no dtc's are present. i have to un-install the BD and then re-install it to get the code to go away. whent he code pops up the truck goes into limp mode and has no power. What could be the problem?
Old Apr 23, 2008 | 05:23 PM
RSWORDS's Avatar
Does it trow the code with the BD un-installed?
Old Apr 23, 2008 | 05:43 PM
Wyatt Earp's Avatar
It is most likely the Bully Dog product not interacting with your ECM properly. Do you have the most recent download of the product? Can you see the code or codes with another OBII scanner? Have you tried sorting it out with a smarty box?
Old Apr 23, 2008 | 07:50 PM
solostyle's Avatar
it does it without the bullydog. i hooked a MAC tools scanner and it reads the code but it wont earse it. it will say it is erased with 1 code remaining and that is the code. i have to unistall the download and reinstall it. i have the version 2.4.1 i believe.
Old Apr 23, 2008 | 09:57 PM
TEXASPOWER's Avatar
u might be under boosting wat boost levels are u running
Old Apr 23, 2008 | 10:54 PM
solostyle's Avatar
its laggy at first of course but i have taken it to 56lbs. not sure how much more it has. this code seems to happen when im eazing on the throttle
Old Apr 23, 2008 | 10:56 PM
Wyatt Earp's Avatar
If you can take it that far and you don't have studs that's about as far s you want to go because things start to implode at 60 pounds.
Old Apr 23, 2008 | 11:11 PM
TEXASPOWER's Avatar
the only time i though that code was starting in forth flooring it and holding the brake just bearly movin smokin people out maybe u just have to mush lag at first u got a quad boost fooler
Old Apr 24, 2008 | 09:03 AM
staarma's Avatar
Yep, you need a boost fooler on there.
Old Apr 24, 2008 | 03:25 PM
solostyle's Avatar
i have a boost fooler. i have the other fooler that plugs into the stock turbo on the way. hopefully that is the problem
