oil delimma
Old Mar 14, 2014 | 09:13 AM
oznation's Avatar
Default oil delimma
ok so its not your normal should I go synthetic or stay conventional or what brands best kid of thing. I bought my 03 5.9l used and it now has 88k miles on it and is time for its oil change. Well the dealer sticker says syn on it, but I would like to just use conventional. Is there a way to test if its synthetic or not? I have heard once you go synthetic you cant go back to conventional. Im just wanting advice on which way to go. Thanks
Old Mar 21, 2014 | 12:06 PM
steved's Avatar
Run whatever you want, it won't cause leaks. I swapped back and forth several times and never had a leak...traded it off with 275k and not a drip.
Sent from my SAMSUNG-SM-G730A using Tapatalk
The leak thing comes from a synthetic removing deposits that in turn causes leaks. Diesel rated oils have so much detergent even in the conventional oils, its not a problem.
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
jhprice
Mar 29, 2015 09:36 PM
coors_man_2005
Dec 15, 2014 10:23 AM
