mods
Old Mar 13, 2014 | 01:14 AM
achenbach7's Avatar
Default mods
I was wondering what the best first mods are to do?I Was reading about the denny t fuel pin and the 3200 gov spring, but I was wondering if I needed to do anything else before those two mods?
Old Mar 13, 2014 | 08:47 AM
92betsy's Avatar
Fuel psi, EGT, and boost gauges.
Then read through here - FAQ/Knowledge base "How do I...?" Look here first! A.K.A. "The Sticky" - Dodge Diesel - Diesel Truck Resource Forums
You should find plenty of good info.
Old Mar 13, 2014 | 10:11 AM
the.beard's Avatar
Also, it's best to build a solid foundation before you start making power. Exhaust to keep air moving and EGTs down, you might consider head studs if you're going to reach for big numbers and kill the KDP; it's relatively rare that they fall out but when they do it's a pain in the a** at best, catastrophic at worst. Bulking your transmission and brakes up a little couldn't hurt, either.
Old Mar 13, 2014 | 05:32 PM
achenbach7's Avatar
So far I have an after market air filter and exhaust.
Old Mar 13, 2014 | 06:37 PM
the.beard's Avatar
Gauges next, then.
Old Mar 13, 2014 | 06:48 PM
achenbach7's Avatar
That's what I was thinking
Old Mar 17, 2014 | 11:06 PM
achenbach7's Avatar
Can the fuel pin and spring ruin the transmission on a automatic? I've been told the spring and pin can ruin a auto transmission.
Old Mar 18, 2014 | 03:39 AM
the.beard's Avatar
, no. Not unless your transmission is already on the way out or you're doing ******* stuff like neutral drops. People don't give the Torquflite nearly enough credit.
2004LB7
29
Feb 29, 2016 06:00 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
lb7Garrett
Chevy/GMC Duramax 01-04 LB7
Feb 15, 2015 09:02 PM
dieselpowa
Jan 26, 2015 03:02 PM
rtbcoop
Dec 30, 2014 02:13 AM
