Cleaned AIT and MAP P0234 still happening..
Old Mar 12, 2014 | 11:26 AM
BigWhiteDude's Avatar
Default Cleaned AIT and MAP P0234 still happening..
I cleaned my AIT on top of the cylinder head with contact cleaner and a small swab also cleaned the sensor on the air inlet tube..MAP?...still getting p0234 over boost code and limp mode. What next? Do I replace the sensors or pull off the wastegate? Can I test the wastegate somehow?
Thanks
Old Mar 14, 2014 | 09:38 AM
dangerous1965's Avatar
Boost fooler! What turbo you running? Do you have a boost gauge?
Old Mar 15, 2014 | 10:22 PM
That's what I was thinking. I plan on the staple power adders (aef intake, smarty jr, 5" SS exhaust) . Does the smarty jr have a fooler?
Thanks for the reply
Old Mar 17, 2014 | 11:23 AM
cerberus60's Avatar
No, Smarty does not boost fool.
If you are getting an over boost code something is likely wrong with the WG controller. A $40 boost fooler will usually solve those types of codes. A Smarty will stop over boost codes from the WG controller.
Old Mar 17, 2014 | 02:12 PM
Ok, thanks. I will plan on either replacing the WG or getting a fooler.
