holding the pedal...
Old Mar 12, 2014 | 06:43 AM
David A Cunningham's Avatar
Default holding the pedal...
hello all, im having some issues with my 96 cummins, yesterday i drove it about 10 miles to some see some family, on my way home someone pulled out in front of me and when i let out of the throttle the truck stalled, got out and checked to see if the shutoff was the culprit, but it was working fine, got back in pushed the pedal down about 1/8 inch she started and ran, but as soon as i let out of it she stalled again, same issue all the way home about 10 miles, as long as i keep the pedal down just a little bit it will run, what can cause this? the day before it would regularly hold about 700 rpm on the dash when warmed up, and about 500 when cold (20 degrees outside),
Old Mar 12, 2014 | 01:04 PM
4x4manonbroke's Avatar
Your idle screw is not set correctly.... 850 in gear with a\c on ... 900/925 idle
Old Mar 12, 2014 | 02:54 PM
how do you adjust that? and they can just drop off without warning?
Old Mar 12, 2014 | 03:19 PM
Back of IP ... 10mm wrench .... Its kinda hidden ... But it's there
and yes they can back off once the jam nut comes loose
Old Mar 12, 2014 | 03:52 PM
JBearSVT's Avatar
I have to adjust mine twice a year just from the seasonal temperature changes.
850/900? Really? That seems really freaking high. Mine idles at 800 in neutral, and everyone is always asking me why my engine is racing.
Old Mar 12, 2014 | 05:31 PM
the.beard's Avatar
...and here's the low idle adjustment screw on the back of the pump:
Old Mar 12, 2014 | 05:38 PM
im guessing turning it out raises the idle?
Old Mar 12, 2014 | 05:40 PM
JBearSVT's Avatar
Depends on which direction you turn it.
Mine idles just under 750 in Drive, IMO it's perfect.
Old Mar 12, 2014 | 07:50 PM
Ahh ... I was close ... Mine idles @ 900 in gear ...
Old Mar 13, 2014 | 04:06 PM
JBearSVT's Avatar
Then shutting it off sounds about as healthy as stopping a bicycle by tossing a stick in the spokes.
