Intermittent power loss
Old Mar 11, 2014 | 07:29 PM
oznation's Avatar
Default Intermittent power loss
My truck sat for a week and when I came back once in a while when I get on the throttle either from starts or rolling starts my truck feels like it's not got any power? It's an 03 with 88k miles and has a smarty programmer. I did try changing it to stock and it still does it.
Old Mar 11, 2014 | 08:09 PM
sinwagon's Avatar
manual or auto?
Old Mar 11, 2014 | 08:11 PM
oznation's Avatar
Auto also the lift pump is original
Old Mar 11, 2014 | 08:21 PM
sinwagon's Avatar
first thing i would check would be water in the fuel filter or even a clogged filter. then look at the trans for low fluid/burnt fluid. my 06 at for a long time and the trans filter stopped up the first time i drove it.
Old Mar 11, 2014 | 08:23 PM
oznation's Avatar
Ok I drained water from the fuel filter tonight when I got home. It didn't make a difference.
Old Mar 14, 2014 | 09:39 PM
oznation's Avatar
So I cannot narrow this down at all. Should I go ahead and look at replacing the fuel pump or the injector pump?
Old Mar 16, 2014 | 05:05 PM
peterpar's Avatar
Im interested also I have the same problem but mine is a manual and an early 04
Old Mar 17, 2014 | 07:24 AM
oznation's Avatar
I threw double the amount of diesel kleen in it and ran the **** out of it. Everything is fine now. So it must have been some water or funk left in it from a bad filter.
Bighouse
Apr 9, 2015 06:51 PM
krg3590
Mar 15, 2015 08:57 AM
Cougdiesel
Oct 19, 2014 10:09 PM
