head gaskets blew no suprise
Old Mar 11, 2014 | 01:40 PM
bajahigh's Avatar
Default head gaskets blew no suprise
was on my way to ohio back to college yesterday and blew the head gaskets which it was fine when going over 10mph i first noticed it when i got off the highway so i am not sure how long it was blow while i was driving on the last highway of my trip back to ohio but i manged to get it home it blows white smoke like crazy lost coolant like crazy it almost overheated i already got the egr delete and oil cooler and intake manifold gaskets, n turbo bolts what else do i need besides head studs which i found for $420 anyone know where i can get em cheaper?? i found gaskets for 170 thought that was a steal and yes the ford oem should i go with the 18mm or 20mm dowel pin?? how much does it cost to get the heads decked??
Old Mar 11, 2014 | 07:50 PM
Adrenaline junkie's Avatar
I think 420 is cheap for studs. You should definitely get heads cleaned and decked mildly by a shop with diesel experience. They will also check for cracks ( common sry to say) and put in new valve seals. If you google the ford bulletproofing you will find a complete listing with part numbers. I'm not sure who actually posted it other than guy is good ford tech. Tells u all the gaskets and things u may forget. I would pull the heads and check dowel size then get gaskets while heads in machine shop.
6.0 powerstroke parts list on powerstroke.org. . . It's pretty comprehensive list . . Sry bombers, hope nobody offended
Last edited by Adrenaline junkie; Mar 11, 2014 at 07:50 PM. Reason: Automerged Doublepost
Old Mar 11, 2014 | 11:06 PM
bajahigh's Avatar
ok also i may still be under warranty ik for a fact the warranty paper was in the window when i bought the truck still have it the vins match and everything but ik i didnt pay any extra for a warranty i got it used for a lil dealership with about 10 cars on the lot guy buys repossesed vehicals n sells em ......think im safe to get the dealership to cover it??and will my coolant filter and exhaust void the warranty i can put the stock intake on take the chip out n put it back on stock its a sct livewire and put the intake elbow back on ....also have the 3.5 pipe coming off the intake elbow will that void the warranty???
Old Mar 12, 2014 | 07:24 AM
Can't hurt to check but I would wonder who is doing the warranty work? If you know you are good wrench I would just do it myself.
Old Mar 12, 2014 | 09:58 AM
bajahigh's Avatar
if its under warranty could i still get money from the dealer and then do it myself??? could prob do injectors to doing it that wat
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
Adam65
Jan 9, 2015 11:50 PM
Oct 31, 2014 08:10 AM
Hardcorefx4
Oct 6, 2014 07:47 PM
