Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
Want to build a pulling truck
Old Mar 10, 2014 | 08:30 PM
TheMacster's Avatar
Default Want to build a pulling truck
So I want to build a pulling truck. I have a 97 F350 crew cab long box 7.3 E4OD 4x4 Dana 60s and a 78 F250 reg cab long box 460 4spd 4x4 busted Dana hp44 and 60 rear. I plan to run a P pumped DT466. What truck would be better? Should I run Dana 60 axles? Rockwell 2.5s? Transmission options? Thanks guys.
Old Mar 10, 2014 | 11:20 PM
Irish_Alley's Avatar
run a dodge with a cummins. i just ran this weekend. since my gmc didnt come with a cummins they put me in the modified class even though i had a stock motor. i did a little bitching asking why i wasnt running with a 89 dodge but i had to run with a 24v and two duramaxs that where chipped, no way in hell i could do anything against them. but i was little engine that could and i failed
Old Mar 11, 2014 | 06:04 AM
biged681985's Avatar
if im not mistaken, the dt466 is to big to use unless you pull for show only. a dana 60 will not hold up behind a diesel pulling. a dana 70 wont hold up long behind a slightly higher horse diesel. dana 80 is about the largest you can go unless your wanting to pull against the 2000hp trucks.
the crew cab long be would be best if your just wanting something to play with. it will meet the work stock class.
it really just depends on how much money you want to spend.
good luck
Old Mar 11, 2014 | 12:39 PM
TheMacster's Avatar
I have a dodge with a Cummins. 2 actually. I want to run in the outlaw class I think. So when I turn up the DT I will rip apart any production axle then? I'm kind of leaning towards the 78 because it has no electronics and lots of engine bay and needs new axles anyway. Would the Cree cab really have that much of an advantage?
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Mikeyfz45083
Nov 14, 2014 11:04 AM
Oct 14, 2014 08:40 AM
