What Does Valve Lash Sound Like?
Old Apr 23, 2008 | 09:40 AM
Wyatt Earp's Avatar
Default What Does Valve Lash Sound Like?
My truck has a strange idle which is way more evident when the tank is low on fuel. I just filled it this morning so it will be a while before I drop it and look at the pick-up tube. Then there is the VP44 - does anyone know if the return line on the older trucks is as porblematic as the newer ones?
Last night after work I started it up and popped the hood and sat there for a bit with my head right up near the fuel filter canister it sounded to me as though there was a sucking sound which could have been a slapping sound or something similar?
The truck has 160,000 km on it.
It will get completely re-wired when the weather improves but that is because of the electrical gremlins...
Old Apr 23, 2008 | 11:44 AM
DangerousDuramax's Avatar
It sounds like a loud ticking or tapping depending on how bad it is and will increase or decrease with RPM's.
Old Apr 23, 2008 | 12:19 PM
Wyatt Earp's Avatar
Doesn't sound like a tapping sound and isn't noticable while driving.
Old Apr 23, 2008 | 12:46 PM
Whit's Avatar
Site Mascot
loose rockers will be more evident when the motor is cold..............they tighten up with heat
VP-44 return line issues.............none
when I installed my Fass I used my OEM supply line as the return...since it is bigger
Old Apr 23, 2008 | 01:12 PM
Wyatt Earp's Avatar
Whit, the motor is hot at this point. No issue when cold.
Old Apr 23, 2008 | 03:43 PM
Whit's Avatar
Site Mascot
if the noise quits when ya get up to operating temp then it aint yer rockers
this is wierd.........hard to explain sounds on the internet makes it tough
Old Apr 23, 2008 | 03:44 PM
Whit's Avatar
Site Mascot
add 24-30 ounces of 2 stroke oil and tell me what it sounds like then..seriously
do yerself a favor and add the oil while its running........you will be amazed
Old Apr 23, 2008 | 04:09 PM
Wyatt Earp's Avatar
You think the sound might be oil pump related then?
Old Apr 23, 2008 | 04:29 PM
Clunk's Avatar
I think he means add the 2 stroke oil to the fuel tank.
Old Apr 23, 2008 | 06:37 PM
Whit's Avatar
Site Mascot
add the oil man
I bet yer sound goes away
nuttin to do with oil pump
add the 2 stroke oil to yer fuel tank
