1995 1500 6.5 turbo diesel
Old Mar 7, 2014 | 02:28 PM
crowe45's Avatar
Default 1995 1500 6.5 turbo diesel
OK a couple months ago I bought this 1995 6.5 turbo diesel it has 240k miles and it was OK at first now I'm having problems. When starting after the truck has set all night I can crank it and everything is fine I can drive it but it has a little bit of an inconsistent sputter for awhile. But and but will stay running but if I go somewhere go inside and park it for like 30 or more minutes when I go to get back in and crank it it will crank run for about 10 secs and shut off and won't start up until I try cranking it for bout 20 seconds while pumping the gas. Now if the truck is only off for 5-10 minutes it will start fine. I have already put 3 different pmds on it please help me out really struggling
Old Mar 7, 2014 | 03:34 PM
racer55's Avatar
Air leak in the fuel lines or filter housing leaking?
Old Mar 7, 2014 | 04:27 PM
crowe45's Avatar
No not any that I know of
Old Mar 7, 2014 | 05:06 PM
racer55's Avatar
The only good way to tell for sure is to replace the IP fuel return line at the frt of the IP with clear diesel rated hose and with the truck safely parked and idling-watch that hose for bubbles.
Bubbles mean air in fuel usually pre lift pump.
A leaking water in fuel sensor or fuel heater can also let air in when the truck sits shut off.
6.5jones
6.2L & 6.5L Performance
11
Apr 3, 2017 01:38 PM
Brclouse
Nov 18, 2015 08:44 AM
Snoobly
Dec 11, 2014 11:59 AM
Oct 24, 2014 04:40 AM
gremlin75
Oct 6, 2014 06:10 AM
