No 4wd
Old Mar 6, 2014 | 01:23 PM
DodgeJohn2013's Avatar
Default No 4wd
Just this past week my 4wd stopped working and I don't know whats wrong its a 2001 2500. I put it in 4 low and it changes all the gearing it doesn't turn the front wheels though. Any thoughts?
Old Mar 6, 2014 | 02:26 PM
lauber_03's Avatar
check your vaccum lines that go to the front actuator
Old Mar 6, 2014 | 03:17 PM
98cummins's Avatar
You can also physically check the actuator to see if it is working if you get your hands on a hand vaccum pump. Mine did this but it was just the eclip inside the housing that came off and let the actuator slide out of the housing a 1/4 inch rather than sliding the fork across to engage the front axle.
Old Mar 6, 2014 | 05:31 PM
lilmike1540's Avatar
Most of the time its the vac lines by the t-case that pop off if thats the case put zip ties around them but i would highly recomend you do the vacume actuator delete just look on ebay type in dana 60 CAD 150$ more then worth it for the peice of mind as diesels and vacume usualy dont mix ...
Old Mar 14, 2014 | 07:34 PM
killer_cummins's Avatar
Front axle actuator is bad most likely,
Need post count to 25 just trying to get there
Last edited by killer_cummins; Mar 14, 2014 at 07:34 PM. Reason: Automerged Doublepost
Old Mar 15, 2014 | 12:59 AM
adub12valve's Avatar
Also make sure the fork didnt hop off
Flikkie2001
12
Aug 29, 2015 10:03 PM
2gCummins
Jul 22, 2015 11:34 PM
mw1095mw
Jan 4, 2015 11:06 PM
lifted07sierra
Nov 24, 2014 10:22 PM
7.3stroke
Oct 15, 2014 10:50 PM
