need help fast
Old Mar 3, 2014 | 08:39 PM
06ford's Avatar
Default need help fast update
changed my mind on the hole deal just ordered a valair clutch an valair hd clutch hydraulics
would I be alright running a set of 175hp injectors. currently running ats 3 piece manifold 4in turbo back exhaust air dog 100 edge cts with attitude clutch should be in by Friday if all goes well looking to make some where around the 500hp mark 400 to 500 is my goal thanks guys I also have a pretty heavy foot do a lot of traveling so I want safe reliable power
Old Mar 4, 2014 | 03:20 AM
97cummins's Avatar
Are you running a stock air filter setup?
What do you have in ways of gauges? Because when you put your injectors in, your egt's are going to go up.
If not, I would recommend an egt gauge.
Old Mar 10, 2014 | 08:41 PM
06ford's Avatar
im running edge cts for all my gauges yes im running stock air filter setup. my current setup is 4in turbo back exhaust edge cts juice with attitude air dog 100 ats 3 piece manifold 550 hp clutch valair hd clutch hydraulics everything else is just stock
Old Mar 12, 2014 | 08:21 AM
jkidd's Avatar
without a turbo upgrade I would not do more than 100hp injectors and even that can be hot.
Old Mar 17, 2014 | 12:43 AM
Devon527's Avatar
Without a bigger turbo you're going to max out before those numbers you want to see
jimmer4dat
Sep 9, 2015 06:08 PM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
stevenb86
Mar 8, 2015 10:02 AM
