need help asap
Old Mar 1, 2014 | 10:19 PM
dman001232's Avatar
Default need help asap
2004.5 6.0 running really bad. Using alot of fuel 1/4 tank for 50 miles, no power takes miles to reach 70 on a flat road if I go up hill I slow, I hit an overpass at 70 I slow to 40 or less regardless of throttle, idles horrible, shakes while driving, belching s##t ton of dark black smoke. Had a egr cooler delete put in back in September was the egr valve supposed to have been removed also? Please help asap only vehicle I have to get to work and my wife is pregnant and has to travel 40 miles to the doctor once a week.oil pressure gauge shows good batteries are good.hard warm starts cold starts not too bad but still not right.any and all help would be much appreciated.thanks
Old Mar 2, 2014 | 07:33 AM
prison's Avatar
Do you have access to a scan tool. What other mods do you have? Is your air intake clear? If you already know this just ignore the next part. The black smoke is unburned fuel normally too much for the amount of air put in. Does your turbo surge? I just had mine surge, my veins were sticking and I still didn't get any real smoke to speak of but I had no power and couldn't get over 2600 rpm but I had a combination of problems
Sent from my iPhone using Tapatalk 2
Old Mar 2, 2014 | 10:03 AM
dman001232's Avatar
No access to scanner. No other mods that I know of. New air filter turbo seems to make a kinda of pulsing sound while driving and loosing power it'll make a make a muffled pop sound some times and the motor cuts out when it does it.the turbo is during a lil oil when I took the breather tube off yesterday.
Old Mar 2, 2014 | 10:04 AM
mysterync's Avatar
You really need to find a qualified shop to take a look or buy some type of obd2 tool. It'll be required to do much of anything with your truck!
Sent from my SCH-I605 using Tapatalk 2
Old Mar 2, 2014 | 10:08 AM
prison's Avatar
I would probably take it to an auto parts store and get them to check the codes. They will tell you what they are but write them down anyway and look up those codes. You might be out a turbo on this one. I think what you call pulsing is what I call surging. Had it surged on occasion before this?
Old Mar 2, 2014 | 10:21 AM
dman001232's Avatar
Autozone scanned and only found temp sensor bad no other codes. The pulsing us the best way I know to explain it.almost like when you roll down a window on he hiway and iT makes that loud 'pulsion'
Pulsing noise sorry my phone is apos.it does this all the time for a couple months
Old Mar 2, 2014 | 10:23 AM
prison's Avatar
My first look would be at the turbo, also check all the boots and look at the intercooler. Other members might have some other advice as well
Old Mar 2, 2014 | 10:27 AM
mysterync's Avatar
They found a fault code related to a temp sensor. That doesn't mean the temp sensor is bad!!!
Old Mar 2, 2014 | 10:34 AM
dman001232's Avatar
It was bad the plug was broke off when I had egr cooler delete installed I got a new one though
Old Mar 2, 2014 | 10:44 AM
mysterync's Avatar
Cool deal, too often have folks come in and say "this is bad, the parts store said". Each time we have to explain why it must be diagnosed etc.
