Switched power source location?
Old Mar 1, 2014 | 07:01 PM
Renteria1217's Avatar
Default Switched power source location?
Can anyone tell me where I can run a switched power source from my fuse box that is switched on when the key is on and not constant?
NM I figured it out.
Last edited by Renteria1217; Mar 1, 2014 at 07:01 PM. Reason: Automerged Doublepost
Old Mar 3, 2014 | 02:44 PM
Devon527's Avatar
Windshield wipers and power windows just to start. Get a cheap test light and find the one you want by testing key-on and key-off. What are you tapping into those for?
Old Mar 3, 2014 | 10:25 PM
I can't get my raptor pump to run off the plug it plugs into. It will run for a second and shut off. If I run it straight to the battery it runs fine.
So I was going to run it to a switched power source
Last edited by Renteria1217; Mar 3, 2014 at 10:25 PM. Reason: Automerged Doublepost
Old Mar 3, 2014 | 10:33 PM
Devon527's Avatar
Does it run for a second then shut off when you turn the key to on? Because that is usually just the pump building up to pressure and shutting off
Old Mar 3, 2014 | 11:36 PM
It will prime like normal and then shut off after the truck runs for a few minutes. So at first I ran the power to the battery through a fuse-able link. It would run a few minutes and then blow the fuse. So I just ran it straight to a power source and it stays on.
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
