oil in coolant
Old Feb 28, 2014 | 09:19 PM
hondardr10's Avatar
Default oil in coolant
So I just did oil cooler o rings on my 1995 7.3 and now there is oil in the coolant and coolant in the oil.... I'm guessing I pinched a o ring or something? Or is it something else possibly?
Old Feb 28, 2014 | 11:34 PM
joebob3093's Avatar
Moderator
Could be injector cups I think
Old Mar 1, 2014 | 05:27 AM
hondardr10's Avatar
Well it did this on the test run after the oil cooler, it had approximately 10 mins on it since the new o rings, the time it took me to start it, let it warm up, its 12° here, and get to a parts store foe coolant.
Old Mar 1, 2014 | 09:56 AM
MAFoElffen's Avatar
I'm sure you are right. If you did notice it before, especially while you had it openned up... put it back together and poof! Pretty straight forward.
But just in case, you asked "if" it could be something else, Could be, but not as likely-- +1 to bob's injector cups, it could also be a head gasket... But like we all suspect, those are not as likely as a pinched or misaligned o-ring.
Then after you asked, you support what you already knew was going to be the most obvious! That's funny! It's 12 degrees outside and you are stalling going back out there to tear it back open aren't you(?)
LOL. I feel for you. Not like that hasn't happened to me before. We are not perfect and things do happen sometimes.
Tobyk
Jul 7, 2015 08:01 PM
Bull Grunt
May 15, 2015 09:55 AM
coors_man_2005
Dec 15, 2014 10:23 AM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Chevy/GMC Duramax 01-04 LB7
Nov 9, 2014 04:49 PM
