518 swap gone bad
Old Feb 27, 2014 | 03:25 PM
Naturalkindaguy's Avatar
Default 518 swap gone bad
I recently had a 518 swap done on my 89 d350. The truck just doesn't shift properly. I have messed with the TV cable over and over and just cant seem to get it right. If I unlock the cable, it seems to shift too soon, and too smooth. IF I lock the cable on the first setting, it tends to wind out and I have to let off the accelerator to make it shift. During this swap, is there anything extra needed to make it work? The overdrive is hooked to a switch and it will shift to OD when I turn it on. Im at wits end, and am going to take it to a TRUSTED tranny guy as soon as I can. My main question is, Are there any required pressure sensors or such to make this swap work correctly? I would greatly appreciate any help, and any advice.
Old Feb 27, 2014 | 04:23 PM
12vcummins96's Avatar
no pressure sensors are needed what is the condition of the tv cable
Old Feb 27, 2014 | 05:07 PM
TV cable is in great shape. I'm wondering after I got your response If it's a valve body issue. If I unhook the tv cable it shifts fine but, I know if I'm on a hill I could force the tranny to slip. I'm very upset with this swap. I feel like now I should have just got a gear vendors.
Old Feb 27, 2014 | 10:22 PM
the.beard's Avatar
I know it's much better to isolate your issue and fix it, but I'd thought I'd just throw it out there that a manual valve body would work, even if as a last resort (or second-to-last after re-swapping transmissions). I might even have one or two laying around if you get so fed up that you decide to go that route.
|WYG|SS
Jul 4, 2015 08:31 AM
Ryans71
Diesel Engine Conversions
Mar 7, 2015 09:38 PM
ReckONE
Feb 25, 2015 09:41 AM
Feb 5, 2015 12:10 AM
Jgloveracob
Nov 16, 2014 07:27 AM
