Head stud problem
Old Feb 26, 2014 | 08:30 PM
ferrari90quad's Avatar
Default Head stud problem
I have a 98.5 dodge that I put in a 12v block, anyway when I had the head of I bottom taped all the holes in the block for the studs to go in. WHen I went to torqe down the studs in sequence did the steps to 125 the stud way in the back of the head keeps slipping. the stud itself threads down into the bore of the block just fine but when you go to put torque down on the nut the stud itself seems to back out and become loose and you cant get torque on it..... anyone ever have this happen? what else can I do?
Old Feb 26, 2014 | 09:28 PM
lilmike1540's Avatar
Is there a helicoil in the specific bore ? Did you run the stud down snug then put the nut on and try to tighten
Old Feb 27, 2014 | 06:07 AM
no helicoil in the bore. and yes I ran the stud down snug put on nut then it slips
Old Feb 27, 2014 | 07:16 AM
mysterync's Avatar
Could could try a helicoil or other type of thread repair. I personally wouldn't do it but it would likely be ok. If it blows a gasket or the stud continues to pull before taking torque you could always pull the block and have it machined for the bigger studs.
Sent from my SCH-I605 using Tapatalk 2
Old Feb 27, 2014 | 08:16 AM
Yea that is really touchy i would imagine you put studs in because you want to make some power and any kind of helicoil or thread repair is going to be iffy and it sux cause its the very worst one it could be as far as repair goes
Old Feb 27, 2014 | 09:09 AM
Yeah it's the farthest one in the back. I'm Gona try a head bolt Tommorow see what happends. I drove the truck I out 60 psi threw it a couple times. It held but who knows how long it sucks cause I put in tons if money into this truck now this happends
burndiesel
10
Feb 7, 2023 01:15 AM
gd1996
For Sale
May 15, 2015 09:42 AM
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
Adam65
Jan 9, 2015 11:50 PM
twinturbo12v
10
Dec 8, 2014 07:58 PM
