Ring and Pinion gears
Old Feb 26, 2014 | 02:17 PM
CrazyLadysHubby's Avatar
Default Ring and Pinion gears
My truck is getting up in the miles over 200k and I pull a 34ft trailer. Starting to get what I think is a lot of slop in the ring and pinion gears. Need info on who has good ring/pinion gears or should I look at getting a whole rear end assembly? Ive seen G2, Strange engineering, Yukon. Just had axle bearing replaced on both sides. Hopefully I can get thru the events I have to do and get home before the rear end blows up.
Old Mar 17, 2014 | 03:42 PM
RamBow3500's Avatar
Strange is the best,but if the ring and pinion are worn out it should be humming and getting hot...Does it have those symptoms...BTW if the R&P is stock and its a 3500 DW,most produced were 3.73 ratio...
Willey878
Jun 1, 2015 02:26 PM
