1993 dodge cummins 12v hard to start
Old Feb 25, 2014 | 12:38 AM
Josh Chretien's Avatar
Default 1993 dodge cummins 12v hard to start
hey i just got a dodge cummins 12v ve motor its a 93 it seems to run great and all. most times just half a turn and it fires right up but some times it just cranks and cranks and nothing seems to happen, unless i hold it to the floor and it some times will just fire up or kill my battery trying to fire up. it seems to happen on hills more but some times on flat to im not sure what to think put a new filter on it and a new lift pump but still dose the same stuff what els could it be ? it has 260 km on it and no blow by ???? any help would be great thanks guys its making my 6.0 look more reliable at this point
Old Feb 25, 2014 | 09:18 AM
dan123dbl's Avatar
Air in the lines most likely. Next time it sits for a bit, unscrew the bleeder valve in the fuel system and prime the lift pump and see if air comes out of it. It should start up easy after you've primed it. (close the bleeder valve before starting)
Could also try bleeding the injector lines once you've started it up.
Old Feb 26, 2014 | 07:34 PM
i dont think it is i just put a new lift pump in it today and a found one of the lines to be leaking on the injectors so i put all new lines on and filter and still wont start with out ether but when it starts runs great and once its warms up starts right up ?????? thanks man
Old Feb 27, 2014 | 08:04 PM
tiremann9669's Avatar
Worse on hills is common with losing prime you've got a bad fuel line or pickup
Old Mar 1, 2014 | 03:53 AM
thanks guys i seem to bleed the system really well and now its been starting half crank for the last 2 days
PeteBug
Jun 11, 2015 12:16 PM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
trab123
Feb 9, 2015 09:44 AM
rschriek
Jan 26, 2015 07:30 AM
elkmaniac
Oct 29, 2014 07:01 PM
