raptor lift pump problem
Old Feb 23, 2014 | 08:02 PM
cummins addict789's Avatar
Default raptor lift pump problem
Hello I have a 99 dodge cummins with a raptor pump. Got cold enough a week ago to gell up. My truck started running tough. I hauled it home changed fuel filter but now my raptor is blowing fuses and sounds very weak compared to befor. I swapped relays and no diff. So is my pump bad?
Old Feb 23, 2014 | 08:49 PM
lilmike1540's Avatar
Your pump can be service and is probably geled inside the gerator sprocket remove the pump and on the bottom take the four allen head screws out remove cover there will be the pump sprocket and the pump gear they should slide out very easy take them clean them being carful not to scratch or damage watch the oring when doing this when reinstaling make SURE it is clean use some good diesel when reasembling and slide the gerator sprocket back on the slide the outer pump gear back on making sure they slide toger nice and easy make sure oring is in groove clean the mateing surface and put it back togather allen heads need to be pretty tight and the reprime and you should be good also if possible blow through the feed line going to the tank to make sure its not clogged ...
Old Feb 23, 2014 | 09:33 PM
The temp is in the 50s now so does gelled fuel unthaw or stay the same consistency once its gelled
Old Feb 23, 2014 | 09:57 PM
Once gelled it stays gelled
Old Feb 23, 2014 | 10:04 PM
Ok thanks mike ill take it off and give it a good cleaning when I get home. Brake cleaner ok to use on it or just wipe it down and flush I with fresh diesel?
Old Feb 23, 2014 | 10:11 PM
Brake cleaner will take all the oil off witch is a bad thing diesel fuel will clean it really well and the pumps come with a oring kit to do this service as well incase the oring gets tore and your welcome
Old Feb 23, 2014 | 10:15 PM
Ok it was already on the truck when I got it so I dont have a spare o ring kit. Ill be real careful with it and let ya if it does the trick.
Old Feb 23, 2014 | 10:20 PM
Also does the truck have a fuel pressure gauge ?
Old Feb 23, 2014 | 10:27 PM
Has an adrealine v2 programmer on it. Shows my preassure I would like to put an actual gauge on it. Is there one I can put on the fuel filter houseing. Any suggestions for me. The programmer in the cab was sayin I had 69 psi pressure
Old Feb 24, 2014 | 08:31 AM
The raptor isnt strong enough to.produce 69 psi i would say get on ebay and buy a glowshift git there 230$ comes with pyro fuel and boost nithing rong with dual redundancy it is crucial to make sure you have fuel pressure to the vp as that is what kills them and depending on where the qaud is plumbed into the fuel system it will either be on the bottom of the filter houseing or on the inlet at the vp witch is the prime location but as i said fuel pressure is critical for vp life bellow 5 psi and you asking for a new vp above 10 psi at W.O.T is best your raptor is set at 17psi and can be raised
And totaly spaced this have you looked in your tank to see if its ok inside cause it also will not pump if gelled in the tank
Last edited by lilmike1540; Feb 24, 2014 at 08:31 AM. Reason: Automerged Doublepost
