Things to do while swappign motors
Old Feb 23, 2014 | 07:17 PM
Levis95's Avatar
Default Things to do while swappign motors
So after a year of owning the truck and having constant problems with it im finally getting around to swapping out the bad motor and putting a lower mile one in. Current motor has 200k miles on it but was not maintained by previous owners. So I have a 97 that's body is gone that im using its motor (187 k KMS not miles).
So I know to swap the front accessories and such over from my 95 motor to the 97 motor and im actually keeping the 95 turbo because according to previous owner the 97 turbo has bad oil seal. I am also replacing the pitman and idler arms when im in there and re doing all the grounds and cross over battery wires.
My question is there other things I should do while the motor is out and accessible ? The injection pump is new as well . when I do it I ll post a thread full of pictures to help others along
posted two by accident mod can you delete this one?
Old Feb 24, 2014 | 06:04 PM
Mase's Avatar
If your going to do idler and pitman arms you might as well do upper and lower ball joints and tie rods,there is also a arm coming off frame that idler mounts to.New oil cooler lines are a good idea also.
Oct 1, 2015 06:50 PM
Aug 20, 2015 08:30 PM
petew
Jul 2, 2015 05:40 PM
mildbrandd
Mar 20, 2015 05:51 PM
cooler364
Mar 15, 2015 04:13 PM
