leaking water line next to turbo
Old Feb 23, 2014 | 06:05 PM
01trailerpuller's Avatar
Default leaking water line next to turbo
I have an 06 that there is a little piece of rubber water line that is leaking next to the turbo. It connects two hard lines. Does any one know what it is called and the dimensions of it are? This is my only vehicle at the moment. I don't want to tear it out before I have the parts on hand.
Here is what I am taking about.
72 people have looked at this and no one knows???
Last edited by 01trailerpuller; Feb 23, 2014 at 06:47 PM. Reason: Automerged Doublepost
Old Feb 24, 2014 | 04:09 PM
dangerous1965's Avatar
That's the heater core supply line. any heater hose will work don't know the size just take it to the parts store. It's usually a loose hose clamp leaking!
Old Feb 24, 2014 | 06:54 PM
I had a few minutes today and ran by Dodge. They are adamant that it has to be a special hose because of the heat from the manifold. The part is $20 but they shortened it to keep it from leaking. Now it is twice as hard to install. $80 to install it and whatever fluid to top it off. Also it is kinda hard to take it off and go to the parts store when this is my only vehicle.
Last edited by 01trailerpuller; Feb 24, 2014 at 06:55 PM. Reason: Automerged Doublepost
Old Feb 24, 2014 | 07:57 PM
They don't call it a stealership for nothing! Did you try and tighten the hose clamps?
I've never found one with a actual hole always loose clamps!
Old Feb 24, 2014 | 09:48 PM
Mine is coming apart
Old Feb 25, 2014 | 06:52 AM
If you unbolt the bracket on the back you can use a pry bar to get a little flex in the line.
Also use WD-40 to get it on easier. Good thing is you can slide it way past then align and slide it onto the other pipe.
Great time to upgrade the exhaust manifold and turbo!
|WYG|SS
Apr 28, 2015 03:59 PM
CumminsCoalRoller24/7
Apr 21, 2015 09:03 PM
24vmaniac
Mar 4, 2015 12:37 AM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
