Need a new ECM!
Old Feb 22, 2014 | 05:19 PM
slodizzel's Avatar
Default Need a new ECM!
Been trying to figure what's been wrong with my 99 for some time now and it turns out I need a new ecm. Was a huge hassle to figure it out, but now I'm on the hunt for one.
Can anyone suggest any places to look besides junkyards? Been scouring craigslist and some forums with no luck.
Forgot the part# is 3942336.
Thanks!
Old Feb 22, 2014 | 08:39 PM
lauber_03's Avatar
Pure Diesel Power sells them but they are expensive. I got one off of ebay for 200 and then had it reflashed for my truck for 119 through a cummins shop.
Where are you located by the way?
Old Feb 22, 2014 | 08:51 PM
slodizzel's Avatar
Thanks for the info. I'm in San Luis Obispo, updated my profile.
Old Feb 23, 2014 | 08:54 PM
lilmike1540's Avatar
Can you tell me what issues your were having
Old Mar 2, 2014 | 08:39 PM
slodizzel's Avatar
Sorry, didn't see your post.
I honestly have had no issues besides a check engine light. Other than that everything seems to be fine.
On another note I found someone selling an ecm with the same part number as mine. Thinking that if I get it reflashed it should work. Thoughts?
Old Mar 2, 2014 | 10:46 PM
lauber_03's Avatar
if just the cel light is on thats no need for a new ecm! put a scanner on it and see why its on. common issue with failing ecm is that your gauges will not work.
Old Mar 2, 2014 | 11:23 PM
slodizzel's Avatar
Have already run the codes. All signs pointed to the ecm and then I took it to the stealership and they confirmed it was a bad ecm.
Old Mar 2, 2014 | 11:24 PM
I wouldnt dare touch my ecm for a cel the issues you could have by swaping out your ecm are so vast that i would almost flip the coin for a p-pump
jeremiah1
May 19, 2016 04:58 PM
jeremiah1
Jun 18, 2015 05:01 PM
klein444
6.2L & 6.5L Performance
Mar 5, 2015 05:13 PM
Lanceomni
Feb 23, 2015 09:26 AM
PerformanceAuto
Jan 15, 2015 12:32 AM
