1989 gen fuel pin
Old Feb 21, 2014 | 09:17 PM
cummins Pride's Avatar
Default 1989 gen fuel pin
have a 1989 auto tranny 2wd first gen and have had a couple big shot diesel guys tell me I can complete take the fuel pin out and not have to run one has anyone took there pin all the way out.
Old Feb 21, 2014 | 09:24 PM
novapat's Avatar
I guess you could if you wanted to just blow smoke everywhere and run like crap..just remember some of the bigshot diesel guys call themselves that but drive around with leaking trucks and blowing excess smoke.. That is a dead give away of there knowledge!!
Old Feb 21, 2014 | 11:33 PM
that's what I was thinking
Old Feb 22, 2014 | 12:50 PM
92betsy's Avatar
Take the stock fuel pin, grab your dremel and grind down the deep side. Made a huge difference on my truck when I did it. Here is a thread that might help you. Fuel pin grind profile - Dodge Diesel - Diesel Truck Resource Forums
Old Feb 23, 2014 | 12:06 PM
cougar's Avatar
A stock pin is hard to replace, I don't recommend grinding on it. Sacrifice an aftermarket one or make your own from a steel pin.
Old Feb 23, 2014 | 11:28 PM
92betsy's Avatar
When I ran my ground pin I ground out the deep side. If I needed less fuel for some reason I just turned to the shallow side and it drove smokeless. It is a great cheap upgrade and with my ground pin vs my custom pin that is deeper than a stock pin can be. And the only performance difference it gives me is low end smoke control. I also only get the same boost with a stock ground vs my other deeper pin.
Old Feb 24, 2014 | 11:29 PM
eeyore's Avatar
The pin puts in the correct amount of fuel for a throttle setting, I don't know if it would run at all.
Old Feb 25, 2014 | 11:23 AM
idk either
Old Feb 25, 2014 | 11:55 AM
NadirPoint's Avatar
Originally Posted by eeyore
The pin puts in the correct amount of fuel for a given boost level, I don't know if it would run at all.
Fixed it for ya. It will run, just hot and smokey. Not a good idea.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
