parking brake light and abs light on all the time
Old Feb 19, 2014 | 09:38 PM
Richard1949's Avatar
Default parking brake light and abs light on all the time
have no idea why these 2 lights are on, the parking brake light gets brighter when i apply the park brake
Old Feb 20, 2014 | 08:45 AM
BigSilverBullet's Avatar
It's probably one of the sensors on the hub for the ABS system. Do your all of your other gauges function properly? Speedo, Tach, and so on?
Old Feb 20, 2014 | 10:54 AM
dangerous1965's Avatar
Check the switch for the park brake as for the ABS probably a sensor have the code pulled so you know which one!
Old Feb 23, 2014 | 12:06 AM
Khoss's Avatar
Most common for these trucks is a rear abs sensor on the differential housing.
Old Feb 23, 2014 | 10:53 AM
bigreddog's Avatar
Remove the glove box, there's a black box behind it. Unplug the box and wait a couple of mins than plug it back in,and that will fix it. Give it a try and let us know if it worked.
Old Mar 3, 2014 | 02:07 PM
24-valve-monster's Avatar
mine did that too its a burnt out wheel speed sensor that's exactly what happened to mine a new sensor is about $160 and has like 3 month warranty fixed mine right away let me know if this helps.
Radioking1777
Jun 9, 2015 04:13 AM
ValleyF250
Nov 1, 2014 07:56 PM
