info 155cc injector /fass
Old Feb 19, 2014 | 09:05 AM
STEVEFREEDOM's Avatar
Default info 155cc injector /fass
Hi everyone ! noob here !
i just teared my 03'excursion 6.0L apart ...
for injectors job , im looking into RCD 155cc stock nozzle reman injector
since im on tight budget
question is: ive been HIGHLY recommend to install a Driven Diesel Regulated Return Kit
AND fass 125 gph pump.... IS IT A MUST for the pump now?
here's mod/upgrade done so far:
arp stud / oem ford HG / new hpop / powermax turbo W/batmo wheel / air intake / 4" turbo back straight exhaust / egr delete / egr uppipe / new oil cooler / blue spring /
banks high ram / SCT tuner- innovative tune / dc alt
Old Feb 19, 2014 | 05:35 PM
HeavyAssault's Avatar
MUST...no. Do you want the injectors to last? You need something on the supply side for extra support in pressure and filteration. A RR doesn't do squat to protect them from water, air and gunk.
Old Feb 19, 2014 | 06:16 PM
ok thanks,
what do you think about fass pump + driven RR ...VS. AD2 ( which is already regulated) ... from what I read..somewhere !?
Old Feb 19, 2014 | 08:23 PM
Adrenaline junkie's Avatar
I have adII and am on third pump. If I had it to do again I would probably go with low pressure air fuel separator and feed stock HFCM. When I get back to cash flowing again I'm going to install a crossover and check pressure at back of heads with gauge. I'm wondering how much pressure is lost from filter/ regulator to back of heads.
Dfro22
Aug 12, 2015 06:07 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Feb 27, 2015 01:53 PM
Dec 3, 2014 08:10 AM
760DAN
Oct 31, 2014 12:53 PM
