Please help
Old Feb 19, 2014 | 06:51 AM
penn's Avatar
Default Please help
When ignition is turned on you can hear a tapping in the valve cover sounds like injector solenoid opening and closing lasting for one minute. Have a no start situation until tapping stops. Anyone know what this is?
Old Feb 19, 2014 | 09:37 AM
dangerous1965's Avatar
No codes? That's wierd! Start by cleaning all your grounds!
Old Feb 19, 2014 | 12:24 PM
steved's Avatar
Wasn't the 2006 the one that had the corrosion problem on the ECM multi-pin connector at the engine? Might try pulling that and reseating it...
Old Mar 2, 2014 | 08:32 PM
Scambino's Avatar
I have a 05 that does the same, 1st diesel ive owned so I thought it was normal, let me know if you find the cause, thanks: argh:
