93 cummins bogs down at full boost
Old Feb 17, 2014 | 05:22 PM
dwelsh420's Avatar
Default 93 cummins bogs down at full boost
i have a 96 f250 with a 93 cummins swapped in and when I give it full throttle and hits full boost it bogs down. any ideas of what it could be?
Old Feb 17, 2014 | 05:36 PM
sweetv8s10's Avatar
Do u have a tach? If u do what are your RPMs at when it does this? I would guess maybe your maxed out on RPMs and the governor is defueling it maybe someone else might have some other ideas.
Old Feb 17, 2014 | 06:27 PM
dwelsh420's Avatar
no tach. it jus recently started doing it. so im not for sure on what could be causing it. it runs good until I give it full throttle then when it gets to about 15 psi it starts bogging like maybe its getting to much fuel. im so lost
Old Feb 17, 2014 | 08:03 PM
12vcumminspower7's Avatar
Does the engine "sputter" or does the engine get throaty?
Old Feb 17, 2014 | 08:07 PM
dwelsh420's Avatar
yea it sputters but when I let off it runs fine
Old Feb 17, 2014 | 08:20 PM
1stGenForTheWin's Avatar
You need to put a fuel pressure gauge on it, see what you're getting at WOT. Sounds like a lift pump to me.
Old Feb 17, 2014 | 08:27 PM
dwelsh420's Avatar
ok ill look into that. is it difficult to change the lift pump? im new to the cummins motor so not sure on a lot things yet.
Old Feb 17, 2014 | 08:33 PM
Sounds like a dirty fuel filter or low fuel pressure at WOT!Thats my .02 cents
Old Feb 17, 2014 | 08:35 PM
dwelsh420's Avatar
ok thanks for all the input. ill check my filter then ill let ya know if its better
Old Feb 17, 2014 | 08:37 PM
Ok sounds good!
