P0700 limp mode
Old Feb 17, 2014 | 02:06 PM
Sawicki4x4's Avatar
Default P0700 limp mode
Hey guys a recently bought a 03 cummins with a 47re. Last week my cel came up and showed 2 codes one for my heater grid relay and the second is p0700. I had the code scanned and it came up ad a bad tps. I bought a timbo apps and installed it and my tranny is still in limp mode. I shifts fine if I manually go from 1-2-D but it will not go into 4th. I think my lock up is working because the rpms do drop 100 when I'm at a constant speed. Any one have any insight on this. I'm thinking I'm better off dropping it off at the shop that a lot of people have recommended to me. Hoping this doesn't mean I'm in need of a new tranny. Thanks in advance guys
Old Feb 18, 2014 | 03:41 AM
97cummins's Avatar
You said you bought a timbo app, what is a timbo app?
And you said you have a bad throttle position sensor. That could be tied in with your tranny in limp mode.
You may also may have an issue with your valve body.
Old Feb 18, 2014 | 10:54 AM
Sawicki4x4's Avatar
Timbo apps is just an updated tps. From what I understand a bad tps or apps will cause my tranny to go into limp mode. But after I replaced it my tranny is still in limp mode.
Is there anyway to check if it is the valve body.
Old Feb 18, 2014 | 07:11 PM
cerberus60's Avatar
Get it scanned with a scanner capable of reading the PCM so you can get the codes. Without that you are just guessing.
Old Feb 18, 2014 | 07:39 PM
Sawicki4x4's Avatar
I had the code scanned. Came back as a bad apps or tps. I replaced that and I still am in limp mode. I'm bringing it in next tues.
Blake Johnson
Chevy/GMC Duramax 06-07 LBZ
Sep 10, 2020 01:42 PM
ClintD.
Apr 30, 2015 09:38 AM
ClintD.
Mar 23, 2015 04:37 AM
syctaz
Mar 3, 2015 09:23 AM
To fast
Chevy/GMC Duramax 04.5-05 LLY
Feb 10, 2015 09:30 AM
