no throttle
Old Feb 16, 2014 | 11:40 AM
minorthreat's Avatar
Default no throttle
'04 6.0 . lost throttle this mourning pulling out of my neighborhood. hit the gas and nothing happened. truck did not cut off, just no throttle. I didn't let it warm up for long like I typically do. turned the truck off and restarted and the problem went away. anyone know what would cause this?
Old Feb 17, 2014 | 07:33 AM
Adrenaline junkie's Avatar
Throttle position sensor is possible, would probably throw code. The joys of fly by wire!
Old Feb 17, 2014 | 03:58 PM
bobfbigman's Avatar
ICp sensor is most likely cause, if you have a couple sticky injectors it can happen too.
Old Feb 17, 2014 | 08:50 PM
Thanks guys. Ive also noticed its starting to take a secound to crank when cold, then rough idle untill it is warm. No smoke - white or otherwise.
12vWoodHauler
Sep 30, 2015 07:58 PM
Blair@BD
BD-Power
Sep 10, 2015 12:29 PM
Jake202
Jun 21, 2015 09:42 PM
Jmohr52
Mar 4, 2015 01:18 AM
1stgenswap
Nov 3, 2014 09:45 PM
