Automatic to manual transmission swap
Old Feb 16, 2014 | 03:03 AM
1989firstgencummins's Avatar
Default Automatic to manual transmission swap
I would like to do a manual to automatic transmission swap in my 1989 dodge w250 5.9l cummins. I have the 727 torque flite now and was wondering what parts would be needed to swap in a getrag 360 manual transmission.
Old Feb 19, 2014 | 04:13 PM
dezeldoc's Avatar
You are going to need the pedals, clutch master and slave cylinder, bell housing, flywheel and bolts, clutch, cut hole in floor for shifter, crossmember, drive shaft lengthened, neutral safety switch wires re-routed, reverse light wires fitted to 5 spd, and steering column or just remove the shift handle, and above all make sure the rear yoke on the trans is good as they are not to be found!
Old Feb 21, 2014 | 04:43 PM
eeyore's Avatar
I think I will just leave my 525 in that seems like a lot of rework.
Beau_Jacques
Jun 26, 2015 12:17 PM
autostroker
Jun 17, 2015 11:18 AM
Jgloveracob
Nov 16, 2014 07:27 AM
smokee
Nov 7, 2014 07:40 PM
collind82
12
Sep 30, 2014 11:23 PM
