New here and to dodges passenger head lamp wont work
Old Feb 15, 2014 | 04:43 PM
joshs24v's Avatar
Default New here and to dodges passenger head lamp wont work
ok im going to try and give the best explanation on this. i bought an 01 dodge ram 2500 the seller told me the truck had hids but were removed and that the passenger side light wouldnt work after returning it to stock bulbs. the other day i was looking to see if bulb was bad but it was fine there was a broken wire so i got a universal pigtail and replaced the socket no change. i hit the bright lights and the filiment is barely getting hot. i looked at all the fuses under hood and whats beside the door they all look ok. the bright light indicator is on and wont go off even in dim mode. could the multifunction switch be bad. please help i gotta get an inspection and my tag monday before i leave out for work again
just put in new switch the one to go into bright lights, light still doing same also nothing happens unless driverside is plugged in
