No Power at higher RPM 1st gen
Old Feb 15, 2014 | 06:01 AM
93d250's Avatar
Default No Power at higher RPM 1st gen
Hi guys,
I'm a diesel rookie and need some help please.
I have a 93 D250 with stick-shift (getrag)
As far as I can tell, everything is pretty much stock
Everything serviced about 3500 miles ago (fuel-filter / air / oil / valve-lash)
Checked turbo, which has some play, but by no means hitting housing (just under 10 psi boost)
Here is my recently developped problem:
When I need power, like climbing a hill, or even just mildly "stepping on it", it just don't wanna go and even runs "stumbly".
It starts fine and idles great; I get it to move as long as I don't step on it.
First I thought diesel - gelling (cold outside) poured some diesel 911 in tank, seemed to help at first, but now its the same thing.
Before I start tearing into the pump, I was hoping to get a few suggestions
BTW I replaced liftpump about 8000 miles ago and truck always ran great.
Thanks for any help.
Forgot to mention that it has 135,000 miles
Old Feb 15, 2014 | 11:46 AM
cougar's Avatar
I would start by looking at intake and/or exhaust for restrictions/leaks. Look at the entire systems from one end to the other. Next, I'd be looking at fuel/fuel supply restrictions/leaks. Same thing, from inside the fuel tank to the injectors.
Old Feb 15, 2014 | 12:19 PM
1stGenForTheWin's Avatar
+1, I was thinking a leak somewhere in your boost plumbing.
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
Tory4
For Sale
Feb 1, 2015 08:33 PM
dutchsupreme
Diesel Engine Conversions
Dec 13, 2014 12:26 PM
